2010 T4R Trail Edition Lift Kit with KDSS Suggestions
GDMT4R
Hey everyone,
I am thinking about a lift kit for my Trial Edition T4R with KDSS. Are there any limitations because of KDSS when looking for a lift kit? What are your suggestions for a lift kit suspension?
Hey everyone,
Easy folks........maybe he is new. :) OP, you should really use the search function as tons of information is already on this forum about your subject. If you have specific questions feel free to start a new thread or post in a old one that is relevant. Now being in a good mood.
There are not "limitation" to lifting a KDSS equipment vehicle if you keep it the standard 3/2 or less lift and are not looking for long travel (there are not many long travel kits and you are not interested in them based on your question). Now onto lift. Depends on what you are going to do with the 4runner, your budget etc. I will let you search on your own but basic info you can do Spacer lifts, Non rebuildable shock lifts (OME, Bilstein, Toyota TRD Pro etc) or "high end" rebuildable units like the Radflo, Kind, Icon. Although I know new to nothing about your I would recommend a quality kit from OME or Toytec, better then spaces, won't need rebuilding in 20-60k miles and much cheaper then the "Racing" setup
Thank you Engineer, I searched for this question and got a lot of results that were all over the place, so I thought I'd ask to make sure.
Your welcome and thank you for searching before hand! Once you have it narrowed down there should be plenty of info/reviews here. I think I would look into the 5100's or OME first.
Best of luck
I have the same 4Runner but I’m not sure that I have the heated seats unless I don’t know it? Where’s the switch?
seltzernator
