2014 FJ/4Runner wheels on a 3rd gen :)
I believe the back spacing is 4 5/8 or 7/8, a SpyderTrac 1.25" wheels spacer was used to set the wheels out a bit. The Wheel spacer can be deleted if you prefers he sucked in look and possibility of rubbing.
Ran into an issue with the front SpyderTrac spacer as it was ordered for my vehicle, I forgot to adjust the part number for a 96-99 Tacoma with Manual Hubs.... Had a machines hope bore the center larger (essentially the same diameter as another Chinese set I had).
Looks sweet man! I just picked some up myself for my 3rd gen, gonna wrap them in 285 Toyo ATII. Did you ever mount them without spacers?
Those look so good! I wonder if they would clear the 231mm brake upgrade?
Yes, that's what I'm running.
I did mount w/o spacers and it was too sucked in. A set of Spidertrax 1.25" (narrowest they make) takes them just beyond the limited fenders, but not to much.
