2014 SR5 limp mode activated following 'routine' oil change
Jhunt
So desperate here, and this is my third attempt to put this together in a simple, but clear way.
Dealership did oil change. Vehicle ran fine for several weeks, then entered limp mode. After 2 years of stalling (i know, trust me, im a doormat, its not a secret) from the dealership, i decided to run the list of possible reasons for the limp mode, and checked my fluids.
I know this will sound BS, if someone told me this, i would call bull, but i nearly filled a 5 gallon bucket with oil when i drained it. It took 4, 5qt jugs to bottle it up after for my clean up.
And when i checked my transmission, i found 3 things that still make me sweat. My drain plug was stripped, with fresh metal exposed, i only had a few ounces at most of fluid in it, and most importantly, the cover over my oil drain was not only still in place, but the bolts holding it, were rusted so badly, i had to cut the skid plate off after every single bolt snapped while trying to get them off by hand.
What i suspect is, one of their younger guys drained the trans, instead of the oil, and just went wild on filling it back up, or wasnt paying attention or something.
After doing full fluid and filter changes, checking for metal shavings or fragments, i found nothing to indicate physical damage to either engine or transmission.
But she still goes straight to limp mode when turned on, and after the initial tow home, i lost 'drive' entirely, i can only reverse, however, after sticking an endo camera in through the drain, i found no signs of damage to the physical gears that were visible.
I owe a bit more on it, but i want to know if this is even worth trying to fix.
And every mechanic i talk to, says its 'probably' electrical, but no codes are being thrown, and i just had major electrical work after an insurance claim the previous summer, including a new ECM (rear hatch was smashed in a parking lot, and a faulty replacement window motor caused a catastrophic short, per the mechanic that AAA told me to use).
I would prefer to fix it, but if its going to cost me more to fix it, than it would to buy a new vehicle, then it just isnt worth the money or effort.
Jhunt
