2014+ Headlight Socket Need Identified.
ronin4375
Anyone know what type of socket this is? Need to find adapter to convert it to H11 socket.
You could try looking up that Sylvania part number and try to get a data sheet on that socket. Another option would be to try a body shop. They have to replace or repair those things all the time and probably know how or where to research.
90980-11255
https://parts.conicellitoyotaofconshohocken.com/oem-parts/toyota-housing-connector-f-9098011255
If you have access to the truck, you can verify by checking the existing plug. It's marked "11255". Since it's a Toyota specific part, you'll probably need to order the plug and build your own conversion harness. Easy enough to do.
thank you very much. that's what i'm gonna have to do. I just recently converted my 2010 4Runner Trail to the 2014+ Trail/TRD Pro with Bushwacker fender flares. Connected all connections to the new headlights except for the low beam. I didn't want to have to cut through the dust cover and modified it from there. making a harness is easier.
Jhunt
