2014 left turn hyperflash sorry
oljedi11950
Apologies to forum ,but haven't found a decent answer to this (w/o resistor) . Replaced son's low beams with led , had/have lasfit turn signals & shortly after install said leds ,started hyper ? So my olass took out all bulbs front & rear & still hyper . What am I doing or not doing right ? Could older lasfit leds be bad almost 2 yrs old . Thanks ! yes I searched so much now my eyes are watering
You took out the bulbs, didn't put anything back in? Of course they are going to hyper flash; that is how the car tells you have a burned out or missing light bulb.
Older LEDs from most any source will hyperflash because the load on the car isn't what it should be. Lasfit recently changed their design so they shouldn't hyperflash. You should never have to add resistors when you change to LEDs with modern light bulbs.
Ok thx [MENTION=609789]fkheath[/MENTION] , knowledge what i need ! Assuming the left turn lasfit gone bad ,it comes on but doesn't indicate , Preciate the help
