2014 TE 4WD Issue
KodiakJones
I recently had my 2014 TE w/KDSS lifted with a Toytec Boss kit. Now when I use 4WD the truck pulls hard to the right (regardless of whether I am on pavement or snow). This does not happen in 2WD and the alignment is spot on factory specs...
Any ideas as to what may be the issue?
Leave the truck in 2wd, jack up the front right tire, try spinning it to check for any binding.
If that feels ok, get the truck on a proper lift with all 4 wheels off the ground. Put it in 4H and put the transmission in 1st gear. Check that the front right tire is spinning at the same rate as the others.
Sounds like there is something binding up in the front axle causing the pull. Could be a bearing that isn't set properly, or a number of other things that happened during the lift work. Good luck!
No lights on the dash? When I had my OME springs installed in October the tech broke the right front ABS wire. I verified that the 4WD worked and had to drive it that way for a couple weeks before I could get it fixed, simply knowing I didn't have ABS, A-Trac, or the extra 4 lo functions. But I wonder if something isn't signaling your traction control to drag that right front brake?
As far as I know the KDSS shouldn't have anything to do with it pulling to the side at all.
youngrk
