2017 4Runner TRD Pro
TRD PRO 57
Hello, I have a new TRD Pro any suggestions on oil and fuel additives? Also would adding any additives void any warranty's? Thanks
What kind of additives? Most are just snake oil scams and don't do anything. Just stick to the factory recommended oil and change it at the advised intervals.
One of the few fuel additives that works is the Chevron Techron (old formula) but you have a new car so you won't need it.
Im pretty sure you don't want to use any at this point, especially a oil additive. If the vehicle is new then your using break in fluids until your first service.
Maybe snake oil, but i use Chevron Techron Fuel System cleaner...because i don’t fuel up with Chevron much. I read somewhere that doing the Chevron is a good thing especially if you fuel up with crappy gas...Chevron Techron (which is also in their gasoline) is a pretty good cleaner from what i hear.
This is not that important anymore if you put in top tier gas (Shell, Mobil, Chevron). I don’t...so, i use the above cleaner.
AndiGarage
