BettysNephew
My LE has twice "gone dead" in a fashion. All power is lost when this happens, lights do not work, clock needs reset, keyless entry inoperative and I have to use the key to unlock door to even get in. As I said just like a battery cable has been removed. After a short time everything returns to normal for no obvious reason.
Is there a cutoff relay somewhere in the Toyota wiring that could cause such a catastrophic shut down? I could not find anything like that on the diagrams for older 4R's but thought perhaps it might be on newer models. I had a remote start installed by the store that does all of them for the dealership and he said there is nothing that would kill all power in their install.
I am getting suspicious of some sort of battery issue but when I checked the voltage on the battery while everything was dead it read 12.8v which would be within normal range. There seems to be no corrosion on battery posts that is apparent but I will be cleaning and coating with Noalox or similar compound.
Any other suggestions are appreciated as I volunteer for American Red Cross Disaster Action Team and cannot afford to have an unreliable vehicle.
