2019 Limited 4WD whining/howling noise under power
I have a trd pro and it has zero whine. Our 4th gen that is now my sons car has no whine. Even the old 3rd gen diff transfer case rear end has zero whine. My 08 Tundra had a whine coming from the rear diff but I changed all the fluids using Mobil 75w -90 and the noise went away.
I bought a 2019 4Runner 2WD SR5 in June. It exhibits this whining noise exactly as described. I have not taken it to the dealer yet but will report what they say whenI do.
Has anyone gotten any resolution to this issue?
Took mine in to the dealer a couple of weeks ago and went for a ride with a tech. He heard the whining noise and said he would drive another 4Runner on their lot and get back to me.
He did get back and asked me to bring it back in. I take it in tomorrow and will report back with what they find out, if anything.
Just dropped the 2019 4Runner at the dealer. Went for another ride with the tech to confirm the whining from rear diff. Looks like they are going to replace the differential. Hope that fixes it. 2750 miles.
I really like this 4Runner. I have a 1997 4Runner with 200K miles that has been a great car, though I did buy a 1992 Toyota pickup brand new, that threw a timing chain at 49000 miles. Just hoping this 4Runner doesn’t become a problem, because I got rid of a Honda CRV to buy this car when Honda couldn’t/wouldn’t fix the car that only had 35K miles on it.
2019 4 Runner SR5 whine/howl at HWY speed
Took my 19 4 Runner in today for the same whine/howl noise between 60 - 70 mph. Was told that there is a TSB to correct this issue. Replacement of the rear drive shaft and mounts are needed. Parts are on order will follow up when done.
2016 Limited 4WD and a 2004 SR5 V6 4WD
Regardless of the mode of operation, I have not noticed any sounds coming from my drive lines or center differential. Everything is pretty much silent as far as I can tell.
Damn my 2020 Off Road with 3000 miles makes the same exact whine between 60-70 when I’m pressing the gas and when I let go of the gas the whine goes away
I had the same noise on my 2014 SR5 2wd. around those speeds, if I lightly hit the throttle i could consistently make the noise. Went away if giving more gas or letting off completely. I always thought it sounded like some intake noise hitting a resonant tone or something. I do not have the same sound from my 2018 OR.
So...I took the 2019 4Runner 2WD in last week and they replaced the rear differential under warranty. I saw on the service printout that the parts and labor would be about $2200.
Still makes the EXACT same noise at exactly the same speeds:sobbing::shrug:!
My 2015 Limited sounds the same with 58,000 miles as the youtube video. yes this truck is louder than my previous 4runners. My 4th gen sport was super silent. I don't think it's a problem, just normal for this truck.
I owned a 2005 SR5, it had the same noise that started around 5k. I had a 2016 SR5, with the same noise that started after the first oil change at 10K. In both cases it was determined that the noise was coming from rear differential but nothing could be done as it was considered normal by TOYOTA. In other words, it is a *FEATURE* not an issue!
It was very frustrating dealing with the dealer to address the noise so in the end, got rid of both after living with it for 58K and 43K respectively. I bought a third one but this time I went with a TRDORP with a locking diff. So far I have 10k miles without the dreaded rear diff. noise however, it has a different noise issue that i think is related to dragging front brakes.
If I were you, I recommend you live with it or get rid of it to save your sanity! It will drive you nuts. It is unfortunate, that Toyota won't address this seemingly prevalent issue via a less stressful and time consuming means.
mine does it, exactly as described on this thread.
2015 trail edition (with rear locker). 90,000km.
between 60 and 80kmph, if I am applying the throttle lightly (as I pretty much always am between 60 and 80), it quietly howls/whines. The moment I let off the gas, it goes away.
I've been living with it since last summer. I can't tell if I only noticed it when I got rid of some other noises, or it just started then. It drives really well. My gas mileage isn't great, but it's not horrible.
I just assumed it was the pinion bearing preload washer.... but some of you guys have had the rear and replaced with the same noise afterward...?
Per my above post, new differential did not fix the problem. So, either the replacement differentials suffer from the same problem, or...the whining is not coming from the differential.
But since the whining ceases when you let of the throttle, that signals (at least to me) some kind of “lash” in the drivetrain SOMEWHERE.
Any mechanics on here want to chime in on the cause?
So I purchased a 2020 Off Road Premium, up from my 2018 Off road, because I wanted to new features, radio blah blah blah. I live in Colorado, and had to start using the 4 wheel drive almost immediately. Noticed a whine, under deceleration, then to a howl/moan/roaring noise between 30-50 mph in 4 wheel high, under acceleration. Thought maybe tires, lifted the vehicle with the same kits they charge 12k for on the new ones they sell here, noise still present. Changed the needle bearing to the ECGS clam shell bearing, and noise is still present. Take it out of 4 wheel drive and noise goes away, take foot off accelerator pedal, noise goes away, over 50 or under 30 in 4 wheel hi, nothing. The vehicle now has 3500 miles on it, and I am set to drop it tomorrow morning for a resolution. I have driven so many 4 wheel drive Toyotas over the years, the is my third Runner, new one every 2 years as I used to work for Toyota, had three tacomas and a FJ Cruiser, and have had all of them lifted and never one single issue. I am super in tune with my vehicles, so this is disturbing, and I will go all the way up the corporate ladder if this doesn't get fixed. It is definately in the differential, as I can also feel it in the steering wheel and the floor panel under the driver side. I am not sure if this is the same as what you guys are having an issue with, but I will let you know what ends up happening.
2016 SR5 with 35k and I have the exact same ‘whine’ mine is only under load (when I’m getting on the freeway or passing cars) above 4K rpmish
Ok guys, as mentioned, my 2019 4-Runner had a whine/howl at hwy speeds. There was a TSB for replacement of rear prop shaft and mounts. Work was done and noise is gone.
Bumping this thread.
I've a 2019 TRD OR that exhibits the OP symptoms 100%. I'm not sure if this is a new sound or was always there.
Those who have posted in this thread with similar issues, were there any updates?
I've a dealer appointment on Thursday but not sure if much will come out of that.
2021 4 Runner Whistling sound
Bought a new 4 Runner a week ago- has 300 miles on it now and when I hit 20 MPH I hear a whistling sound. Can't tell exactly where its coming from as you can hear it on driver, passenger and back passenger areas. It gets faint at 60 MPH. Noise isn't constant- but enough to drive me crazy. I've read where several Tacoma's have this issue-
I had a 2017 same body style and all never heard a noise like this.
matisgugle
