2020 4Runner TRD Off-Road Premium
Modification of the vehicle?
Magnuson Moss act has you covered in that regard. Not sure how a steel bumper would affect any warranty outside of what it directly affects. Meaning, your steel bumper has nothing to do with your exhaust leak, or a throttle body issue, or a transmission fault. Since the bumper isn't a mechanical or working part, I don't see what it can directly affect...
As said before by papadop88, the bumper will not affect your warranty, there is a possibility that it could cause malfunctioning of the tss (I don’t think it will) so keep that in mind!
I did my research and it looks like victory 4x4 is a company that stands behind there products, get in touch with them.
I ordered the C4 Low Pro bumper without the bullbar so it wouldn't interfere with TSS. You have nothing to worry about. I've had safety sensing tech on . my past three vehicles. I've lifted, lowered, changed out bumpers and all sorts and I've never experienced any safety sensor issues...
First time poster, first time 4R owner. Got my 20 super white OFR-Premium about two months ago. Built a full google doc of all the add-ons...so many options.
I'm going to black out the emblems soon with plasti-dip and trying to see when the aftermarket Pro grills come out so i can see if it is worth the price difference from the OEM. Does anyone know of a Cali dealer offering the 2020 pro grill parts for the same discounts that a couple of others have mentioned in this thread?
Picked mine up just over a month ago, there are quite a few here in Colorado without KDSS. However, Stevinson East was able to find me 1 of 2 MGM's in Colorado at the time and did a dealer trade for me. Found several red/white/blue and black all available when I was talking to Stevinson and Groove Toyota.
My Requirements were:
TRD ORP
MGM
KDSS
MoonRoof
All Weather Mats
I moved nearly everything over from my 2010 Trail. I replaced the lift since it had over 100k on it and was starting to leak from the front shocks. Gobi rack was moved over last Monday by Gobi, haven't had a chance to get my light bar back on yet or my ditch lights.
Well this doesn't make any sense to me but if it works I'm in too. Keeping an eye on this thread.
It doesn’t make a lot of sense to me either. For whatever reason, the iPhone 11 problem seems to be related to the new charger/connector, not the car. Had the same problem on my wife’s Honda and the adapter fixed it there too. I can make calls just fine on Bluetooth but CarPlay does not work not through the cable unless this adapter is in place. Hope it works for yours too.
TRD ORP
MGM
KDSS
MoonRoof
All Weather Mats
Great looking truck! What lift did you install? Can't wait to get my Gobi... looks like a sweet setup.
ToyTec BOSS 2.0 Aluma Series
Thank you, I went with the ToyTec Aluma 2.0, since I’m on the road 95% of the time the 2.0 made more sense to me. I had the Boss 2.5’s on my 2010 and it was not bad in the summer but winter it rode rough especially on the super cold days. I like that ToyTec is local and most of the guys that work there have decked out 4Runners, Tacoma’s and Tundras.
Thanks jcdusn, I just ordered one. If this works it's going to save my sanity. :loco:
Unfortunately, this USB adapter did not fix my Carplay issues with my iPhone 11. I tried several cables with it and it's still just as bad. Echo on the recipient end of the call on Bluetooth and choppy Carplay makes hands free calls almost impossible.
C'mon Toyota/Apple... Need a fix ASAP!
Hi fellow 4Runner enthusiasts. I just picked up a 2020 TRD ORP and planning my wheel upgrade. Does anybody know the OEM PN for TPMS sensors?
I'm having the same issue with my 2020 Tundra. I had an iPhone X when I bought the truck and Carplay worked fine. When I upgraded to the 11 Pro Max I could no longer use Carplay for phone calls due to the delays and cut-outs. I spent a ton of time on the phone with Apple only to be told it was likely a Toyota issue. I haven't taken the time to go to the dealership. Instead I traded phones with my son as his iPhone XR works fine.
I ordered the adapter suggested to see if it works. I have tried another USB-A to USB-C adapter previously and Carplay wouldn't work at all. Hopefully this one will work.
Has anyone taken the time to have Toyota look at the issue? I want to take my truck in, but I feel like this is one of those things that will take forever to get a resolution.
Are there any better deals on these '20 TRD Pro Grill parts?
I found the below; albeit it is basically the same discounted price:
Garnish Front Bumper PZ323-35058 | Boch Toyota South
Grille Radiator Up PZ327-35056 | Boch Toyota South
Does the bar that say Toyota goe directly over the stock bar that has the Toyota emblem... I’m a bit confused on this part because the middle bar is part of the front grille that goes over toward the headlights..
I can’t imagine that you’d cut the center bar off to get the replacement one that says Toyota to be the replacement...
The upper grille part replaces the existing grill with the Toyota emblem. The garnish part will go over the existing middle bar you are questioning. It basically sticks on with double sided tape. You wont have to cut anything. Once they are both on, it should look completely factory.
Toyota: It’s Apple’s fault.
Apple: It’s Toyota’s fault.
2001ATL
