2020 Fog Light Replacement Options
Toyota (Oval): Morimoto XB LED Fogs | HID Kit Pros
Wanderlost folks did a review on them. They look good
Those or the oem led is very close in light output (I've had both). the morimoto has a tad more light but is probably due to having some light scatter. The advantage for Morimoto is if you want the blackout look for daytime. If you don't care for blackout save money and get the oem led's.
Oh, seamless pitch but will be posting up the black oem led fogs used no more than 2 months. Pulled them from my 19 when I traded it
Would not recommend LED "drop-in" bulbs anyway, they have poor glare control and no infrared heating and clearing of the lens during poor weather (when you actually need them).
There is a ton of info on the Tacomaworld post here, relevant links are in the first post:
The LED SAE J583 Fog Pod & Fog Light Review | Tacoma World
I have the Diode Dynamics SS3 pro fogs in yellow. They are excellent.
Thank you for this thread! I will do more research before I pull the trigger. Too bad I didn't grab Diode's SS3 during pre sale haha.
I have the yellow SS3 Pros in the garage ready for install. All I can say at this point is they are legit quality in the box:) Based on the hours of my research to even order them, I think you cant go wrong with the SS3s.
i just got my color changing led's looks like a PITA to just do the bulbs.
Don't bother. Color changing LED lights are hugely ineffective because a they require the emitters to be offset (2 sets for different colors, so neither are in the optimized focal point location). Return them while you can still get your money back...
its not a money thing, im a car fabricator and get them at cost. used these in lots of builds, no problems with them. they have good diodes
<a href="https://ibb.co/ncYGmyK"><img src="https://i.ibb.co/NjJvCqG/IMG-3746-1.jpg" alt="IMG-3746-1" border="0"></a>
<a href="https://ibb.co/r7Qnjhv"><img src="https://i.ibb.co/xC2Vkb3/IMG-1770-1.jpg" alt="IMG-1770-1" border="0"></a>
Yikes. It's not the brightness that's a problem, it's the chip placement. There's no way for the original reflector to control the beam pattern with chips everywhere like that. Those won't be very useful as real fog lights. Instagram pictures are probably the limit.
true, i just took front of truck apart and looked at that cheap fog light, it is more of a novelty than a tool. i realize i need to get rid of it and put a real lamp in there, decided to take that silver bumper cover off instead after i figured out those clip placements.
I put into my wife's 2020 OR Prem the 2in1 fogs. With conversation of Headlights to LED it gives pure white color for both and as well have nice DRL vs. yellow crap from high beam part of headlight. With other changes as TRD wheels, black valances, all against galactic grey looks awesome.
Can you confirm your headlight/fog setup? I'm looking for leds and want fogs to match headlights.
Could we get an update on them and do the headlights kelvin match with fogs?
I put the DD ss3 pros on my 2020 pro. Direct replacement. Just make sure you plug them in the right way and test before you close everything back up. If it doesn’t light up just flip the plug around. Output is pretty awesome and I chose these over the bajas because I wasn’t willing to lose light output with the cut-off insert. Went squadron pros on the ditch brackets though.
MMJR_T4R
