2020 limited lug nut torque
orcking
Manual says 83 ft lb for steel or 76 for aluminum wheels.
I read somewhere else where it said 85
Anyone knows which is the correct one for the limited standard 20 inch wheels?
The owner's manual for my '19 T4R says 83 ft lb for steel wheels and 76 ft lb for aluminum wheels. I found those specs listed in both the "changing a flat tire" section and vehicle specifications section. It doesn't differentiate between the different styles or sizes of aluminum wheels so I assume it is for all (17" and 20"). My guess is it has more to do with the type of lug nuts used (steel - tapered acorn, aluminum - mag flat washer) than size of the wheel.
I do 100 with my torque wrench and call it a day. With 80-85 I always found myself needing to retorque after a few drives which was annoying as hell.
charlesz
