2020, What’s the difference?
camanzer
We picked up a 2020 SR5P. Looking at some things (mainly the grill), what is the difference that’s keeping 2020’s from being compatible?
Primarily, looking to do a knockoff TRD Pro grill but none seem to be compatible. Is it the sensors below the emblems?
2020 is the same back to 2014, and prior to that cosmetic differences only from 2010 model year. 2010 to 2020 are all N280 models.
Yes. The safety sensor box in the front is why you can't use any of the heritage grill replicas that are currently out.
Well I guess you could but you would need to cut some to make it fit. Also, I think the upper grill portion is different, slightly.
Engine bay relays are also different, driver side area had additional box of relays, which I can only assume is due to the TSS. Cabin fuse box layout is also different.
