2023 TRD Sport does the TRD SKID PLATE WORK ON IT?
BADCUDA1
Member
Just picked up a TRD Sport from Hendrick
Does the PTR60-89190 FRONT TRD SKID PLATE work on the 23 TRD Sport?
Toyota TRD sight says "It may not" not doesn't fit the TRD Sport.
should fit, its only a 10 minute install job so give it a try
If I had one in hand I would but I have to order it.
Different approach / lower angle then the sr5, trd off road.
If I remember correctly the issue is it is not compatible with KDSS without a bit of chopping.
Installed the CaliRaised front and trans skid plate for extra protection and easier access to the oil filter. Also reworked the oil pan drain access to make the opening a larger to reuse the OEM access plate for easier access cleanup.
There is a shield that fills the area between the OEM front shield and the lower facia. Can be reused without any additional support. Its a hefty plastic piece and seems fine without any additional support but I plan to fabricate a couple simple brackets just to add a little support the the rear side of the filler.
Had to modify the CR cat shields aka shorten the front a touch to clear the XREAS line on each side. Will get those installed Saturday is the plan.
Ambrose67
