will 305/40/22 fit? any alternative tires that will fit?
Depends on offset of the rims. The tire is only a 29.5" diameter. The T4R accomadates up to 32" with ease... At that width there may be some UCA (upper control arm) rubbing with the steering wheel cut all the way.
:cheers:
They're 31.6". Sorry but we don't have much experience with larger wheel diameters. You're probably looking at 22x9 or 22x10 wheels. Most will have negative (-13 to -25 ) offset to accomodate the wider wheel / tire. I'd imagine spacers might be necessary on 10" wide wheels.
so will 305/40/22 fit?
