22RE Engine Diagnosis
mr1337357
Does anybody know of a good troubleshooting guide?
I'm not sure if these problems are all related but when I got it it would tick at more than 30% throttle.
The oil pressure needle never goes more than a quarter inch past the first line.
Every once in a while it idles at 2k RPM when warm (I'm thinking vacuum issue).
It also sometimes misfires and idles at 400 RPM until I tap the throttle, then it runs fine.
Is it about to die or are these small things that I can fix? It doesn't seem down on power at all.
In my signature is a link to 4crawler. It has anything you will ever need for diagnostic!
Have you tried checking for error codes?
It's OBD-I, so you don't need a scanner.
Just jump 2 terminals and count the CEL flashes.
The full procedure is on here somewhere if you look
Will it throw codes if the CEL is off when the engine is running?
Also I found the vacuum leak. It's on the hose connecting to the throttle body. All the replacement hoses I've seen online are like $70. I'll probably duct tape it shut until my next smog check.
DionicioLives
