greasefingers said:
Koz said:The trip comp showed 0 miles left, so I was on fumes. I gave the attendant a bag of shit about having a 23 gal tank and putting in 24.5 gal. I read a post somewhere else about somebody also putting more then 24 gal in.
Koz
boston_kevin said:there is an air filter/breather in the filler neck, if this gets saturated it can cause problems. I wouldn't fill more than half a gallon past when the pump automatically shuts off.
iFORCE said:It really doens't matter if the trip computer says 0 or 100 miles left. If the gas tank only holds 23 gallons.. then putting 24.5 gallons creates a problem. How does one have a pint of beer in a wine glass?
iFORCE said:All i'm saying is a 23g tank can't hold 24.5g of gasoline. Just wondering where the other 1.5g went.
If the pump clicks.. and you want to put more gas in.. be my guest. I've always stopped pumping when it clicks because I've heard that overflowing it can be bad for the car.
bulldog-yota said:Once you start getting actual gas and not fumes in the charcoal canister it will deminish its capability to trap fumes. This can eventually lead to a permanent CEL coming on. Same as when you leave the gas cap open.
So to those who consistently overfill, keep doing it on the 4R. FIll it up till you see the gas in the neck and let us know what it does in a years time.
