trd_4runnin said:Basically wider tires are going to excel in most offroad categories, with the exceptions being a few inches of mud with hard ground underneath, and mild snow. Really deep mud and really deep snow will both favor a wider tire.
Skinnier tires are going to better on road when dealing with rain, snow, and ice. They will also put less stress on your steering components, and being a lighter tire would arguably get better mileage.
p nut said:
trd_4runnin said:The bold sentence at the top of the article nearly mimics what I said. The difference being that their position is that contact pressure of as skinny tire would excel, rather than surface area of a wider tire. With the two sizes in question only being about 1.5" difference in width I don't personally feel that the difference in contact pressure would even be noticeable.
p nut said:Position: A tall, narrow tire is a superior choice for all off-highway surface conditions
With the two given sizes above, you're probably right, you probably won't notice *that* much difference, but I was merely pointing out your generalized statements.
Also, the author of the article used 285's and 255's and settled on the 255's based on the points given in the article. The examples given even states that there were only 2" of difference.
p nut said:I didn't quote the rest of the quotes, because they were the same. And I do agree with you on those points that were not quoted. I mainly posted the points that I did not agree with.
I'll also add that I am more into the expedition type of stuff, not rock crawling in particular. There are pro's and con's of each different set of tires. You stated that in most off-roading situations, wider tires are better, which is not true. I linked the article to mainly point that out.
