285/45/22 fitment
eddie
does anybody use a 285/45/22 tire size on their 22's? I can get a set at a great price and want to put them on. right now im on 20's with a 285/50/20. any suggestion? i think it will rub the inside plastic shield at a full turn but i dont care about that, just hoping its not anything else. yes i know how much my speedo will be off also... thanks guys!
Yes I am running them but I have a 3/2 lift as well as a wider offset rim. Not sure on your offset but if your rims are in line with your fenders then you should be fine that way. I would have a test fit done to see about the height issue if you do not have a lift. With the lift I had to trim some plastic out of the fender and trim the mud flaps but that is all.
i should have my tires and wheels soon, so im going to do a test fit and hopefully it should work out okay. im sure a lot of it is how you drive it, if you dont need to cock the wheel all the way it looks like it should clear fine...
