K.C. said:You will need a lift & wheel spacers.
Check out Josh's (HB 4x4) signature.
He's an Off-Roading nut!! :awais:
HB 4X4 said::bonk: :yesyes:
...and Kenny is correct, you will need both.
yabedude said:And you'll need something (screwdriver) to take off the mud flaps. And then something else (dremel/cutter) to hack off the inner fender. And most likely, something (plasma cutter/welder) to reshape the body mounts. And finally, a big hammer to pound in the body panels welds that will also rub.
But yeah, lift and spacers (or new wheels with larger backspacing) will work. :satan:
HB 4X4 said:You don't need to touch the body mounts or the body panel welds.
yabedude said:I completely disagree. If you're flexing, your rubbing. I've got 285/70/17 BFG AT's and they used to rub before all the hacking I described. Think I'm alone? Ask others that wheel.
yabedude said:03 V8. ARB front + Winch. CBI Rear w/tire carrier. 1.5" body lift.
OME-N142/OME-897 rear, N140S/OME886 front. Camburg UCA's. America Racing Crater Wheels w/4.5" backspacing. Custom rear cargo drawers. Lots of weight. I read how some folks are fine, but I wasn't and I know others that went thru the same mods as I did to stop the rubbing. Cutting back the the body mounts just behind the tire was the biggest hassle. The rest was quick and painless.
rook said:No rubbing and I've been on some very rocky trails.
