285/70/17 Wheel Fitment & Offset - MK Wheels
TXLX1
I searched quite a bit and couldn't find a definitive answer. I am upgrading to at 3" lift in front and 285/70/17 BFG KO with Level 8 MK 6 spoke wheels. I can't determine if -10 offset will fit without significant trimming or if I just need to stick with the 0 offset.
Hoping someone has already figured this out. Thanks.
:smash: 10 mm is less than 1/2 an inch it won't make a difference assuming your wheel width is the same between the two offsets.
Wheel width will be 8" on both options. I understand its about .4" just wasn't sure if it was going be a large difference with the tire arc changing.
A little more info, it will be Toytec Boss lift with SPC UCA.
I'm running 3" lift, 1" body lift, 285/70-17 on 17x9 -12. I had to push fender liner forward, trim bumper corner slightly, body mount chop, and remove mudflaps. 17x8-10 would be a good fit with slight trimming.
I know it's not exact size of what you're looking but I have 285/65r18 (32.91") with 18x9 4.56" backspacing (-12mm offset) on a 3" lift and it required quite a bit of cutting, trimming and heating to stop the rubbing.
Thank you all for the information. I think what I will do is lift it, and try out my buddies -12 from his GX if timing allows.
Do you have any head on pictures that show how far tires stick out?
H.Sikina
