285/75/17 BFG Km2's
HOJeepster
Just installed the BFGoodrich KM2's in the 285/75/17 load E. The factory specs are 11.3 x 33.9 and weigh 63 pounds. Stock sport rims weighed 26 pounds, so these are about 89 pounds on each corner.
In reality, they are a tall, skinny tire and measured about 33.5 tall and 10.5 wide - not as big as I thought they'd be - but really a perfect sized tire for this trucks setup.
I compared these to my old 275/70/18 - and the km2s are slightly taller and a bit narrower then the Duratracs. The KM2's have a slow speed rumble, then smooth out nice and quiet about 10mph.
These definitely look good in person.
Not many people running this size, but I'd have to say, they are a great practical big 33.:thumb3:
Those tires are great. I ran 33 inch KM2's on my JK and they are phenomenal on the trail. Stepped up to Trail Grapplers in a 35 after that, but they're damn heavy. KM2 is a great compromise in weight and performance.
NICE! You beat me to getting mine on. Going with +2'' suspension in the front with FJ steelies so I'm waiting to do the body mount chop until I get them on(if they even need to be chopped at that point).
They really are nice and tall/skinny. I was super pumped to find that after mounting one up.
You running a body lift?
I am running a 1 inch BL. Even then, I think you can run this size and not rub too bad. I body mount chop is needed I'd think. Otherwise, it's a great size. Again, not has big as I though it might be...just perfect really. Tall and skinny and burly. I will say, having this be my first m/t tire, they run a bit loud. Loud enough to remind you that it's a burly tire. Not super confidence inspiring on the canyon highways, but ok. The duratracs I was running seemed to like the road better, but the tradeoff was expected switching to an m/t. On the trail, they seem to be more capable.
My initial reaction is 'yes' instead of 'no' - however, I think the body lift only helps while in full articulation offroad. I don't have my welds hammered down yet, and no rubbing while offroading.
