285/75/17 toyo mt's.....how do i fit them??
jayjaytuner
anyone know if a 1.5" bl, and 3/2 spacer lift would fit these??
i know the stocks are 30.56" high 10.43" wide
and these are 33.82" high 11.22" wide
also, does anyone have any pics of there t4r's with 285/75's??
From all the threads that I've read on here, it could fit but need to do trimmings on the plastic parts of the fender wells. I don't know enough about the M/T's, but aren't they little bit more knobbier? If that is the case, it might rub even more.
I just installed 32's (technically 31.9) AT's and had slight rubbing. I trimmed the inner liner and mudflap. I do not have spacers because the right wheel offset takes care of it.
But your will need spacers - either way. From what I can tell, 33's (almost 34); will require trimming.
Do not be scare of this - the inner fender lining is cheap, thin, plastic - you can cut with a sharp knife. There are two bolts on the driver and three passenger. I unbolted and cut "like paper" with a pair of snips. It took 20 mins.
forgot to ask or question weather the factory limited 17's would work, with the reccomendations you guys gave trimming etc. or would i need to order a 17" rim with a certin offset or whatnot??
285 will need spacers with the factory 17's (they will work) or if you find the right offset (probably - 10 to 0) w/o spacers.
more importantly WHO is that chick in your avitar? Presta wont gimme any info on his. :cry2:
