2nd Gen 4Runner rear window sensor?
buzzworms
Sorry if this issue has been covered to death. This is a specific rear window issue.
On two recent trips my '93 4Runner covered 30+ miles of dusty, washboard, gravel roads in southern AZ & NM. When I arrived at my destination the rear window lowered fine. When I attempted to raise it w/ either console switch or rear key switch I got the alarm beep-beep-beep as if the tailgate was not properly closed. The rear wiper was properly seated. Big problem in the backcountry along the US-Mexico border w/ an unsecured truck full of gear. The trip out sucked, literally. TONS of dust sucked in which coated everything. An hour back on pavement and it works again! The same sequence of events on a later trip. The window worked fine on pavement. Twenty miles on washboard and it won't raise after being lowered. Back on pavement after a few hours and it works again! Vibration is clearly the culprit but tough problem to isolate & solve when it self-corrects. A friend w/ a 2nd gen 4Runner had someone bypass a "sensor" or circuit IN THE TAILGATE which corrected the same problem. I've had it checked out at a few local Toyota places and the relay is unlikely to be the source of the problem. Anyone know of a sensor or circuit in 2nd generation 4Runner tailgate that can be bypassed?
rear window sensor
you can pick up the whole black box or blue box that sits inside the rear interior panel on the drivers side up at a junk yard for about $10 i have picked a couple due to the same problem but i have only had to change mine once and i always find that pulling the tailgate panel off and making shure the lock switch is making good contact with the sensor its a little tab you can just bend so it makes good contact.
just a quick fix
good luck
Better to fix it than ghetto fab a bypass.
From first gen experiences...
Make sure the latche(s) on the tailgate are free. They have to 'click' twice closing the gate on a first gen.
It could alone be a loose wire near the motor or a bad ground connection.
Grab a wiring diagram and a Volt-Ohm meter, it will help.
Jlabellajr695
I moved your question about your 2014's rear window from here in the 1st Gen section to a new thread in the appropriate 5th Gen section where you should get some help.
Click here
