Hi and Should I Retire My 1995 Runner?
I’ve had it for 27 years and I am starting to find nagging little problems with it (rear gate engine is gone, a/c refrigerant isn’t available, or timing belt will go soon (had one timing belt replace at about 150k) will need exhaust work soon )
I got bad news yesterday. My 4runner has blown a head gasket. It recently overheated and started spewing coolant through the reservoir. I brought it to my mechanic and he replaced the thermostat and flushed the cooling system but to no avail. It still runs but it heats up really quick now.
The frame and body are solid, with very little rust given it’s age
What do you think? I love this vehicle, but how much is too much?
Hello, this is my 95 4runner SR5 V6 4WD automatic with a 4 inch pro comp lift on 33x12.50r15s, which I'm in the process of 5vzfe swapping
Sent from my SM-S911U using Tapatalk
Hello, this is my 95 4runner SR5 V6 4WD automatic with a 4 inch pro comp lift on 33x12.50r15s, which I'm in the process of 5vzfe swapping![]()
After a long layoff, I'm finally back in the game with another 2nd Gen rock crawler. It's a '93 with a 4" Trail Gear SAS, and corresponding leaf suspension in back. Unfortunately it is using the 3.slow V6, but dual cases give it some extra gearing to help out. The exhaust manifolds have thankfully been capped, so there's no dreaded crossover pipe to cook the head gaskets into oblivion. No , I did not do the build--I was looking for a clean stock 2nd Gen to start with, and found this instead, with all of the running gear (except engine) that I would've added, already installed and proven. I'll be adding action shots as I get them.
All my 4runners that i built have been 3.0s. Never had issues with them. Ran upside down, on its side and all that jazz. People that have issues with them don't do maintance or check fluid's, in my opinion.
Sorry to disagree with you, but it's an absolute proven fact that the design of the exhaust system is what causes the head gasket issues with those models. It doesn't have one single thing to do with maintenance or fluids. You've just been lucky, my friend.
