BE4Runner
I'm currently dealing with what I think are u-joint or driveshaft related issues on my 2000 2WD 4Runner. The symptoms are as follows:
Does anyone have experience switching a 2WD 4Runner to a one piece driveshaft (i.e. no rubber coupling)? It seems I can either get a one piece for $300-350 online, or the Toyota replacement shaft for $500+. I know replacing the u-joints is an option, but I'm worried if the rubber in the driveshaft is the issue this won't fix the problem, and I am staying at an AirBnb in Houston for the next month so I don't have my tools with me or space to work myself to hammer them out. I should be able to replace the entire driveshaft much easier.
Any suggestions on which direction you would go, aftermarket single piece (Toyota Replacement Driveshafts) or Toyota replacement (37110-3D070 | Toyota OEM Parts |*DRIVE SHAFT | Genuine Toyota)?
- 'Clunk' when putting the truck into drive
- Squeaking for a couple minutes after the truck sits overnight. Speed of squeaks increases with speed, seems to be driveshaft rotational speed and not tire rotational speed
- Vibration while driving. Seems to be always present a little bit, but it's bad above 63 mph when OFF the gas - there is a loud deep rumble (like a rumble strip) and accompanying vibration
