FS: 1st GEN Sequoia Whole/parts, $1 Nebraska
Marasmus' Toyotas
Junior Member
With just over 250,000 miles, I am selling this 2001 Toyota Sequoia SR5 4WD for parts, cheap cheap.
Body and frame is available
Interior is grey mostly, with spares of the woodgrain pieces in grey/black
Never used parts (All OEM Toyota parts)
Rear shocks and hardware (bushings and nuts)
Front Lug bolt (that gets pressed into wheel bearing)
Parts that have been replaced in the last 4-5 years: (All OEM Toyota parts)
Tierod ends
Lower Ball Joints
Metal connecting pipes for transmission cooler
All rubber hoses to and from transmission
Sparkplugs
One ignition coil
Driver's front lock latch assembly
Headlight+fog light+instrument gauge+dash light bulbs
Front brake pads
Rear pads and rotors
Driveline fluids
Engine Air Filter
Parts that are NOT available:
Cruise control switch
Brake light switch
Engine assembly
Transmission
Fuel Pump
Fuel Pump relays
Fuel Pump resistor
Instrument Gauge
Gas pedal
Immobilizer Box
Ignition Ring
Charcoal Canister
ECU/BCM/TCM (Engine, main body, transmission)
AC Lines
Exhaust
Power steering lines
Steering Shaft
Badging
Driveshafts (Propeller Shafts)
TireSizeDB
