3.0 to 3.4 engine swap
Treeman
Is it possible to drop a 3.4 in a 95 runner? I have read several post stating that the 3.4 is just all around a better engine. I have 180000 on my current engine and the previous owner didnt take care of this truck at all. This week alone I have replaced all the front end suspension, new brake lines all the way through, which led to new fuel lines and sending units, man the list just goes on and on. My oil pressure is weak, it leaks oil out of every spot imaginable, and has no power. I know that a rebuild is in my near future, but if a 3.4 swap would be the smarter thing to do, then why not.
If this is possible for my model rather easily, could some one let me know what obstacles I might encounter and what mods would have to be made. Thanks for any suggestions:peace:
You really won't find much in the way of help here for that topic, unless you wanted to debate the merits of the swap. I would dig up some links for you from Yotatech or Pirate4x4 but the filter we have at work will not allow those sites. Do a search on both forums for best results.
^^^second that on Yotatech.com. I'm a member there and they have several threads on that topic. The trick is searching the right way.
The 3.4 can be swapped in fairly easily. A tricky part is the wiring.
But if you have a complete donor truck the whole job is easier.
A little searching will get you tons of info.
