I have a 95 sr5 and its supposed to have a 98 motor in it. It plainly states 3.0 when you pop the hood so I'm a little concerned. Can anyone verify at least the possibility that I have a 3.4 but maybe a 3.0 (manifold cover)? Thanks for any advice
Would anyone happen to know if and where it might be printed on the motor whether it is a 5vzfe? I was given all the paper records for a 98 engine swap into a 4runner but I just skimmed it over...I'll have to take a better look I guess.
hmmm...well I looked and found where it states on the front of the block 3vze...it looks like the first photo.
Of course I don't want to believe that I was blatantly lied to so I'm now wondering if its possible to use the top end of a 3.0 but replace the bottom with that from a 98 model???
I looked over the extensive paperwork I was given and checked the vin#'s and everything looks legit. The seller even had a paper that was notarized from the auto recycler that stated the details..."put 98 4runner engine in place of a 95"
More details that may help my cause...
98 4runner engine - $1600
all new gaskets to change 98 to 95 - $58
timing belt, water pump, oil filter...no price on these
and TFJ, your missing your coolant res cap![]()
i think in 98 4runner they had the 3.0 3vz available that might have been swapped in.
not the 5vz 3.4L.
not conned just you thinking of a different motor.
the top end of a 3.0 will not work with a 3.4, in fact nothing from a 3.0 is interchangeable with the 3.4, not even the air filter. bolt patterns are different, intake comes in on different sides exhaust is all different you have a 3.0 man sorry but you were lied to. the paper work is forged. the motor mounts are totally different, as well as the bell housing/bolt pattern on the transmission. id take it back to the place you bought it from and tell them you want your money back.
I'm trying to verify this but I'm not having any luck...anybody else think this could be the case?
