3.4 Head Gaskets
954RUNDEN
I had heads rebuilt. Put on engine with new head gaskets and new head bolts. Torqued head bolts. Cam cap hole was stripped on 2 bolt holes. Took head in for heli-coil.
Do I need to get new head bolt and new gaskets or can I use the ones I just bought.
You can probably re-use the head gaskets if you never ran the engine, I would. Can't help you on the bolts as I don't know if Toyota used torque to yield bolts and if you are using Toyota head bolts.
2001ATL
