Good morining all. I will be adding the Toytec 3' coil overs (112-620 coils) with Bilstein shocks all around and 2" rear Toytec Super Flex Coils
Also have the JBA UCA that i will be installing on my 2017 SR5 4runner with 4x4.
My questions is: what is the best method for relocating the front sway bar if i'm going to have an issue with the coil-overs hitting? I've seen relocation brackets, is this my best option?
I would like to keep the bars as i drive winding roads on my daily commute.
Last question: Do i need to install bump stops for the rear? if so does the size match the rear lift: IE . 2" lift = 2" block?
