Check to see if your catylitic converter is clogged, also check your ignition timing, Toyota want's it to be 10 BTDC, but I set mine to 7 or 8 + or - and my mileage went from 16 to 20mpg, and the power was sweet, it could definitly out run my 86 22RE. Also when I did my timing belt somebody had not set the pulleys up right, so when I set it right when I put it together, I noticed better performance as soon as I set my ignition timing.
