315/70 R17 vs toytec 3/2
R1FIGHTER
I ran across what I think is a good deal, if i can use them. BF A/T 315/70 R17 tire height on H2 wheels. 90% tread and wheels are perfect. will these fit or is this tire to tall? I can't seem to find the offset specs for those wheels. I'd run them on those wheels...
thanks in advance for any and all input
I don't think your going to be able to fit those. Those are 35's, and 35's are hard to fit with even a real suspension lift and body lift much less just a spacer lift. My 33's barely fit with significant trimming and cutting of the body mount with a Cornfed 3/2. You could get them to fit, maybe, but you will be cutting for days.
Suspension lift, body lift, LOTS of trimming. body mount chop and re-gearing. Not such a deal in the long run.
well if you start slow, it will be easy to fit em on later,
-first buy a real suspension kit
-then get a BL
-then get sliders cause if your plan is running 35's i hope you plan to wheel it
-then do the body mount chop
-get wheel spacers if you are running stock wheels
-then get a schrockworks cause you will want one unless the 35's are just for looks
-then get a new girl friend
-then buy 35's
-then re gear at the same time if not very shortly after
and thats about it:party:
simple... right?
Well it would be hard with a spacer lift and not a real suspension lift. You should do it though, squeeze em on there!
So it's a pass. thanks everyone for chiming in. What size do ya'll recommed for my lift? I'm really leaning toward the Nitto Terra Grapplers.
