32in tires
I have 32x11.50 on 15x8 with 4" BS and it required MAJOR trimming, hammering, grinding and cutting to clear and I have a 1.5" BJ spacer lift.
008-9.jpg~original
009-8.jpg~original
010-7.jpg~original
011-7.jpg~original
012-7.jpg~original
014-6.jpg~original
But yeah, they fit and as long as you don't have a rear bumper or mud flaps you should be ok in the back. :bash:
i have 265/75/R16s on my truck and they fit with a ball joint spacer lift, they might just fit with no lift; and they look the same as 32"s
It does a bit, but most people find it tolerable.
Tons of people run 33's/4 cyl/5 spd/stock (4.10) gears, I did it for years with a little 22R.
33's is right on the edge of needing new gears, unless you want to give up 5th gear (which some people do).
Will 32/11.5/15 fit on a 2nd gen 4runner without a lift?
Yes. I ran that size on my unlifted '90 for a year or maybe longer...can't remember. Never scraped or rubbed, but I didn't really bang it around all that hard. Plenty of clearance on the rear...you might get some rubbing on the front under hard off road use. Course, I had to have the speedometer checked to see how fast I was really going instead of believing what the speedometer said.
Running that size also reduced the performance of the stock rear end, and unless you re-gear, you'll eventually cause some rear diff damage.
I finally ended up having it lifted 4 inches, though, and now run 33x12.50s.
Mine fit after hammering/cutting/grinding 10lbs of metal from my inner fender wells. :bash: I didn't really have to do all that trimming and hammering, but I like to turn and go over bumps so......
I had 31s on my '84 but now have 30.5s- had plenty of room with 31s, just got a great deal on the new tires (31s were pretty shot).
I am picking up a set of 33s and 35s next week in a trade- going to see if I can trim enough or do a body lift cheap and get the 35s to clear. If not I know I can fit the 33s. My 84 is a trail only beast so the regear isn't much of an issue as I hardly ever get out of 2nd gear anyway. :-) Trimming should be pretty easy because most of the area I need to trim is already rusted away... I have decided this winter I am pulling the old beast into the garage and patching all the rust and giving a paint job.
213K miles and the A/C still blows ice cold, and for the past couple years it only gets driven once a month...
