I really want to get some 35s but all I have are 3 inch lift in the front and a 2 inch BL. Will I be able to run with these for road use at the least? How bad will the rubbing be before trimming?
I've got 315/75/16's and I still rub after hammering the pinch weld and i'm only running a 3" lift.
yeah, the OP said he had a 2" body lift too though,
do you run spacers 05ltd???
his sig says spidertrax, with the OEM wheels you have to run spacers, or else those tires will be squeezed against the UCA. My MTZs are 11.8" wide and I'm reaally close to the UCA and my wheel has a 4" bs. So, to the OP, with a 12.5" wide tire you will need some thick spacers if you want to use them on an OEM 15" wheel.
ah, didnt even think about the rub on the UCA... was just thinking pinch weld... good catch there downpour!
seriously though.
his user name literally means "poop" in Arabic...
seriously though.
"Khara" is actually used in Arabic as a distinction on being angry for being late only. As we'd say "Awe "$hit" I'm late to the meet. As one in Arabic would say Awe khara I'm late... It's been confused, but an obvious example of "lost in translation". Been there, heard that, literally. If I'm not correct please make it right. No offense but it may be the guy's name, Arabic or not.
