3inch lift questions
kolelt
Hey guys. My 97 4runner has 3inch daystar lift kit. I bought it like that. And I believe it's just spacers over the stock suspension. I was curious if I wanted to make it more modern and smoother what should I look into ? What type of suspension kit ? For front and rear ! I will go ofroading but not hardcore. Mostly daily driver. It does have 33 tires on right now. But like I said the suspension is stock. Maybe anyone is willing to sell a used set up ? Coilovers ??? I want to keep my 3inch lift.
Complete OME suspension for 96-02 4Runner
Since I have day star 3inch spacers. Do I need to get anything else or could I just get this full kit and use my spacers ?
If you have 3" spacers you don't want to add them to anything else. Unless you modify the front, the CV angles are getting too high past 3" of lift. If a kit requires spacers they will be small spacers, so you can't reuse your spacers unless you use stock height springs.
Hopefully that answers your question. If you google "3rd gen 4runner 3 inch lift" or similar, there are literally hundreds of threads identical to this an will answer inevitable future questions. Good luck :D
Because that kit on toytec says add spacers to make it ,
3 inch. Then how u know what size spacers u need to make it 3 inch like it is now. All I wanna do is upgrade my coils and shocks.
I don't know what size spacers they use, someone else will have to chip in there. I would guess it's a 1/2" spacer resulting in an inch lift meaning the coils alone give 2" of lift.
It's a 1/4" topout spacer resulting in 3/4" of lift. They are used on the 881's to net 3". I used them on my 882's.
Jesse1
