~3k RPM Rev Limiter on 4Lo?? (continued)
borfoo3
Link to original thread:
http://www.toyota-4runner.org/5th-gen-t4rs/203554-~3k-rpm-rev-limiter-4lo.html
Hey guys,
Seemed like I broke the first thread somehow with that video.. can't scroll down past the video to read your comments. Contacted both admins and still waiting, so hoping to continue it here until its resolved.
--------update--------
Tried again in the same spot (4Lo, rear diffs locked), without A-TRAC, and no 3k RPM limiter it seems.. However, it was still bogging down towards the end a bit. Was on S4 so might've shifted into too high of a gear and lost power. Either way, seems like A-TRAC was the cause originally.
Also tried the same spot in reverse gear and had to slow down on the skinny pedal to not fly off the edge of the cliff!! No limiter here, just all 4 tires going strong all the way up. Not the most useful bit of info, but good to know..
It may be programmed to keep rpm down so the ATRAC can work the brakes without overheating them. ATRAC is after all only intended to be used in 4lo and at low speeds.
