3rd gen 2wd Rear Diff Drain and Fill Gasket diameters
bass-o-matic
been to a couple of part stores and for some reason they cannot cross reference the drain and fill rear diff crush gasket toyota part numbers.
Anyone know either the pep boys, orielliys or advance part numbers?
Or the Internal external diameters?
Are the single aluminum or double? or are they plastic?
2WD and 4WD use the same rear axle, all 4runners are 6 lug Toyota axles ergo 2WD and 4WD will be the same drain plug gaskets. The drain gasket is a steel crush gasket and the fill is either brass or aluminum, I can't recall.
Just order them from the dealer, they're about $3 together and as changing diff oil should last 40k miles the price you save from a bargin store is negligible especially when compared to the peace of mind.
If you off road at all I would also recommend changing your drain plug to 90341-18021. Gasket should be the same 12157-10010. Rounded side (crush side) goes to axle, flat side goes to plug head.
