Need help with rear diff stripped threads
Ezlife45
Member
Hi guys,
I was finishing up my 100K service on my 4R and was at the last item - changing rear diff fluid. As usual, everything went smoothly until the last step.
I ordered crush washers, drained diff, filled til oil seeped out fill plug, then I screwed up and forgot to install the crush washer. As I was tightening the fill plug, I thought I was crushing the crush washer. I wasn't.
It seems that the male threads on the fill plug were not long enough to bottom out the plug and what I thought was crushing the washer was stripping the threads. My fill plug is metallic so I'm not quite sure if I stripped the male plug, the female diff point, or both. Now the drain plug just spins and will not come out since the threads are screwed.
Anybody screw up like I did? How do you get the fill plug out?
I know I could drain the oil and go full retard and pull the center chunk out but didn't want to get that deep into it.
Thanks in advance,
Try to pry under the head of the bolt while slowly turning. A standard screwdriver tapped with a hammer can work.
Tried that, can't even get a feeler gauge in there. Also tried grabbing with channel locks, vise grips, etc, turning backwards and pulling, threads don't even start to grab.
Run some baling wire around it. Put some tension on it and see if you can engage some threads while unscrewing it.
wwarren702
