3rd Gen 4Runner
RagoFabrication
This 4Runner features the Rago Fabrication Ditch Brackets and 42" Radius LED Brackets.
3rd Gen 4Runner Ditch Brackets
Ditch Light Brackets give you the ability to run aftermarket LED light pods on the hood of your truck. Each bracket provides a low profile clean look to your truck. Every bracket is CAD designed, CNC cut out of 3/16 inch cold rolled steel, and made in the USA. They are sandblasted then powder coated black to sustain harsh weather conditions.
**Ditch Light Bracket Extensions are available so you are able to add an extra pod for more lighting or a camera mount.**
We offer FREE SHIPPING.
No drilling necessary, simple to bolt-on but some minimal trimming depending on the year of the vehicle.
The ditch brackets and ditch pod packages are in stock and available now on our website at https://www.ragofabrication.com/products/1995-2002-3rd-gen-toyota-4runner-ditch-brackets.
3rd Gen 4Runner 42" Radius LED Brackets
Each bracket provides a low profile clean look to your truck. Every bracket is CAD designed, CNC cut out of 1/8 inch cold rolled steel, and made in the USA. Every mounting hole is machined to use 1/4 x 20 pan head taper screws to provide the lowest surface possible creating a weather tight seal. They are sandblasted then powder coated black to sustain harsh weather conditions.
Note: True 40" curved bar should have an end to end measurement of 42". Please measure your bar to ensure you have the correct size or spacers will be required.
The 3rd Gen 4Runner 42" Radius LED Brackets have not been released yet but will be COMING SOON.
averyberryman061493
