3rd Gen FAQ, Tutorials, & Documentation Reference
Status
Not open for further replies.
ksroqclimber
Owners Manuals
Tundra Brake Swap Threads
Misc.
Daytime Running Lights
MotorVac
- ToyotaReference.com
  • TSB Threads - Toyota-4Runner.org by CBR_GUY_IA
  • 1996 - ToyotaProblems.com
  • 1997 - ToyotaProblems.com
  • 1998 - ToyotaProblems.com
  • 1999 - ToyotaProblems.com
  • 2000 - ToyotaProblems.com
  • 2001 - ToyotaProblems.com
  • 2002 - ToyotaProblems.com
  • CEL - Check Engine Light
  • CV - Constant Velocity (Joints)
  • DRL - Daytime Running Lights
  • FSM - Factory Service Manual
  • ID - Inner Diameter
  • MAF - Mass Air Flow Sensor
  • OD - Outer Diameter
  • PCV Valve - Positive Crankcase Ventilation Valve
  • PS - Power Steering
  • TB - Throttle Body
  • TSB - Technical Service Bulletin
(pay attention to ft-lbs blue or in-lbs brown)
  • Auto Trans Pan Bolts - 60 in-lbs
  • Auto Tran Drain Plug - 20 ft-lbs
  • Rear Differential Fill and Drain Plugs - 36 ft-lbs
  • Brake Line to Brake Assembly - 11 ft-lbs
  • Engine Oil Drain Plug - 20 ft-lbs
  • Front Differential Fill and Drain Plugs - 20 ft-lbs
  • Spark Plugs - 15 ft-lbs or 180 in-lbs
  • Transfer Case Fill and Drain Plugs - 25 ft-lbs
  • Valve Cover Bolts - 53 in-lbs
  • Wheel Lug Nuts - 83 ft-lbs
This thread's Links are focused on the 3rd Gen Toyota 4Runner. Let me know if you have any other suggestions or if you find any broken links.
Ks
make this a sticky please mods, and remove the make this a sticky comments, lol
will add to this as time goes on..... some one should ad the tsb list to this if they have a copy as well as links to the top threads you guys can think of on 3rd gen subject matter.
I just added the lists of TSB's I found for the different years for the 3rd Gen. However, this particular site requires you to buy a subscription to view more than the list of TSB num and name of the TSB/piece it effects. If somone has a better resource for TSB's let me know, this was what I found. NHTSA has a good search tool, but you can't direct link to a results page.
This one should be listed first:
Search
Toyota - 4Runner . org Forum - Search Forums
Others that may or may not already be on the first post, not sure what kind of links you want or don't want:
Toyodiy
http://www.toyodiy.com/
3rd gen modifications
All the Mods that can be done to a 3rd gen 4runner. Contest! Who knows the most? - YotaTech Forums
Bumpers
Bumper List - YotaTech Forums
LED tail light installation
YouTube - Toyota 4Runner LED Tail Light Installation
Transmission Flush
Dropping Pan And Flushing Transmission
Replacing Horns
Replacing 4Runner horns with American Car Horns - YotaTech Forums
Rear extension removal
New To Forum - Need General Info / Help on Replacing my 2001 Bumper End - Toyota - 4Runner . org Forum
One-Touch Roof
http://www.yotatech.com/f2/98-4runn...ct-one-touch-operation-mod-216675/index2.html
Front bumper removal
remove front bumper? and turn signals... - Toyota - 4Runner . org Forum
Wireless Door Lock Buzzer Adjustment
http://www.toyota-4runner.org/3rd-gen-t4rs/48175-keyless-entry-beep-volume.html#post398948
Trouble Codes
http://www.yotatech.com/~corey/tech/dr_z_obd/dr_z.htm
Door Panel removal
Help-need instructions front door panel removal - Toyota - 4Runner . org Forum
FSM
http://www.ncttora.com/fsm/index.
4runners.org
4Runners.org - Maintain it. Mod it.
Yotatech
95.5-2004 Tacomas & 96-2002 4Runners - YotaTech Forums
Hood Scoop write-up
Sport Hood Scooped Hood Scoop FAQ Write-Up - YotaTech Forums
Rear View Mirror Upgrade
http://www.toyota-4runner.org/3rd-gen-t4rs/64786-cipa-36500-rear-view-mirror-install.html#post545630
Power Steering Flush
http://www.toyota-4runner.org/3rd-gen-t4rs/66337-diy-power-steering-flush.html#post561292
Steering Rack Guide
How to: Replace steering rack guide- Pictures - YotaTech Forums
Lift FAQ
http://www.toyota-4runner.org/3rd-gen-t4rs/66976-3rd-gen-4runner-lift-information-faqs.
Rear Axle Seals
http://www.toyota-4runner.org/3rd-g...e-information-replacement-thread-3rd-gen.html
Clock Fix
http://www.toyota-4runner.org/3rd-gen-t4rs/67508-3rd-gen-dash-clock-fix.html
Interior Lighting
Gauge and dash backlighting - YotaTech Forums
CV pics
http://www.toyota-4runner.org/3rd-gen-t4rs/67349-cv-replacment-pics.html
Change Drive Belts
How to: Change Drive Belts 3.4 L 5VZ-FE - YotaTech Forums
4x4 Wire
Toyota 4x4, 4WD, 4Runner, Land Cruiser, Mini, T100, Tundra, Surf, HiLux, Tacoma Section on 4x4Wire
Brake Fluid Flush
Toyota 4Runner Brake Fluid Flush
Timing Belt
Timing Belt
TTORA
TTORA - Maintenance Information - Faq
Transmission Cooler
http://www.toyota-4runner.org/3rd-gen-t4rs/63553-writeup-tranny-cooler-install.html
TRD Transmission Cooler
TRD Transmission Cooler - 3rd Gen 4Runner - YotaTech Forums
Block Heater Install
How to install a block heater (with pics) - YotaTech Forums
DRL Disable
2002 4Runner: DRL Disable With On/Off Capability - YotaTech Forums
Tundra Brake Upgrade
'01 Tundra Brakes installed on '98 Gen 3 4Runner - YotaTech Forums
Top4Runners
Top4Runners.com - Toyota 4Runner Informational Website
Spark Plugs
http://www.toyota-4runner.org/3rd-gen-t4rs/59008-how-installing-3rd-gen-spark-plugs.html
Scangauge II
http://www.toyota-4runner.org/3rd-gen-t4rs/57520-3rd-gen-scangauge-ii-owners.html
Thanks for the suggestions.
I added most of them. Some were duplicates of what I already had.
Added Body, Diagnostics, Other Sites Sections. Added a couple acronyms. Added a number of threads suggested previously bootown
Side Note: Bummer......You can only have 11 graphics in one post. So as I add sections, I can't have cool header graphics for each section anymore. :redbrick: Would be nice to be able to overide that in certain circumstances.....lame.
Status
Trdoffroad916
