3rd gen parts + part out '00 SR5 - Mission Viejo, CA
ChildrenOfBodom
Moderator
FOR SALE: Tons of 3rd gen parts + Parts from a 2000 4Runner SR5 4WD.
CONDITION: Parts are in good working condition unless otherwise specified
PRICES: As listed but don't yet include shipping / PayPal fee. Offers considered.
INQUIRE on specific parts. I own way more than I can individually photograph.
PayPal + Shipping available
All PayPal payments sent as gift, or add 4% to total if sent as purchase.
LOCATION: All items located in Orange County, California.
Items are removed when sold.
Transmission Swap:
R150F 5 speed manual transmission/J-shift T-case with all manual swap parts included $1,200 firm
Includes:
Frame crossmember with M/T transmission mount
Clutch fork
Clutch slave cylinder
Clutch lines
Clutch master cylinder
Manual brake and clutch pedal set
OEM Flywheel for 5VZ-FE
clutch disk and pressure plate
throwout bearing
Front driveshaft
Rear driveshaft
Trans and T case shifters
Metal/rubber shift boot (under the leather one)
Interior trim with near perfect leather shift boot
Reverse and 4wd sensors
Clutch start cancel button
Transmission Parts:
Automatic 4WD shifter unit - $50
Shift lock control unit - $5
Engine/Fuel System/Exhaust Parts:
Power steering pump 3.4 5VZ - $40
Alternator 3.4 5VZ - $50
Fuel tank - $60
EVAP canister - $60
Vapor pressure sensor - $30
5VZ-FE exhaust manifolds pair, JDM (true dual) - $50
Exhaust tailpipe - $20
5VZ-FE (w/manual transmission) starter motor - $50
Interior Parts:
Rear seat pair, leather, oak, with headrests, excellent condition - $150
Sunglasses holder (no sunroof) - $40
Automatic 2wd shifter surround, black w/ trd logo - $20
Automatic 4wd shifter surround, black w/ t-case boot - $30 PENDING SALE
Interior door release handles, specify which side - $15 ea
Rear floor mats, oak - $15 ea
4 spoke black steering wheel, no airbag, damaged leather - $30
Steering column complete with ignition cylinder and matching key - $100 (2 available)
Gauge cluster surround trim, black - $20
Lower dash panel/driver knee panel - $20
Hood pull release handle - $10
Gas door release handle - $10
Gas door pull cable - $10
Front Kick panels, oak, $20 ea
Tweeter covers (good condition) - $30/pair
Tweeter covers (fair condition) - $20/pair
Glovebox, oak - $30
B-pillar lower trims - $20 ea
Dogleg trim (plastic along sides of back seat) - $20 ea
Floor trims along door - Rear:$15 Front:$20 Backdoor:$20
Grab handles (OH-SHIT handles) - $15 ea
Dome lights - $15 ea
Transfer case knob - $15 ea
Shift knob, 5-speed, great shape - $30
Wheel well carpeting - $20 ea
Rear cargo area carpeting - $50
Cargo cover brackets, full set - $60
Cargo cover bracket, single - $20 ea
Cargo panels with large size storage cubby, pair - $60
Door panel armrests, $20 ea
Door panels, oak, full set L+R, $150 or $50 ea
AC knob - $5 ea
AC vent - $10 ea
Climate control faceplate - $10 ea
Ignition surround, black - $10
Ignition surround, black w/ stick on wood trim - $5
Sun visor, passenger, SR5, mirror with illumination - $20
Sun visor, pair, base, mirror without illumination - $10 ea
Sun visor clip, oak - $5 ea
Sun visor clip, black paint on them - $3 ea
Fuse panel cover, NOTICE J, good clips - $20
Jack tools bungee - $5
Switch knock out, oak - $3 ea
Door lock trim surround piece - $5 ea
Door lock tab for door, oak - $5 ea
Dashboard, no cracks. Good condition - $100
Steering column cover, tan - $20
Steering column cover, black - $20
Safety equipment:
Passenger Air Bag from 00 Limited - $50
Seatbelts - Front:$50ea Rear$40ea Middle:$30
Seatbelt buckles - $20 ea
Deceleration sensor $20
Airbag sensor (on frame) $20 ea
Airbag computer module $40
Electrical Parts/Switches:
Manual transmission gauge cluster, 160k odo (No PRND2L lights on manual transmission version) - $100
Manual Transmission Back window switch 99-02 (No ECT PWR logo/button) - $40
Driver's master window switch, OEM, 99-02 only, dual AUTO - $60 ea
Passenger front window switch, OEM, 99-02 only, AUTO - $20
Passenger front door lock switch, 99-02 only - $10
Rear door window switch, black trim - $20 ea
Rear door window switch, Limited woodgrain trim - $30 ea
Rear door window switch, no trim, $15
Back window switch 96-98 - $15
Hazard switch 99-02 - $5 ea
Dimmer switch - $30 ea
RR DIFF LOCK switch - $40
CLUTCH START CANCEL switch - $40
Turn signal/headlight switch - $20 ea
Wiper switch stalk - $20 ea
Toyota SECURITY sensor - $10 ea
Rear heat fan speed switch - $10 ea
Misc relays - $5 ea
Blower motor resistor, working - $10
AC button - $10
Mirror adjustment switch - $20 ea
Door switch - $10 ea
Window motor - $40 ea
4WD computer, Limited Pushbutton 4WD - $40
ADD Relay PENDING SALE
Antenna relay - $5
Running light relay - $5
Resistor module - $5
Lights:
Tail lights 96-00 style with harnesses - no bulbs - $60/pair or $40 ea
3rd brake light unit - $20 ea
RH corner light, 99-02 style - $20
Turn signal lenses 99-02 OEM - $20 ea or $30/pair
PIAA 580 covers - $30
PIAA 510 covers - $20
Brakes:
ABS actuator, 2 available (2000) - $50 ea
ABS sensors, front - $20 ea
ABS computer (2000) - $30 ea
Brake master cylinder 1" AISIN - $40
Brake booster, dual diaphragm - $40
Suspension:
Front Lower control arms - $50 ea or $80/pair
Front Upper control arms - $40 ea or $60/pair (2 sets available with good bushings)
Panhard bar/track bar - $40
Stock front struts with tophats and springs - $40
4WD spindles PENDING SALE
Body parts and doors:
Rear bumper, left corner, silver (limited) - $30 - no damage
Rear bumper, left and right corners, chrome (SR5) - $20 ea - some dents
Rear bumper brackets - $20 ea
Rear door, Left, White - $75
Rear door, right, white - $75
Hood, white, paint is scratched on the right side - $50
Outside Door handles (Available in desert dune or white) - $25 ea
Fuel door, desert dune - $20
Side mirrors, white, 00-02 style, heated - $80/pair or $50 ea
Wiper arms, front - $30/pair or $20 ea
Wiper arm bolt caps - $5 ea
Limited flare pieces, silver - $30 ea (See photos)
Full set of SR5 Sport edition style flares w/ mudguards - $200 PENDING SALE (alex)
Glass:
Rear side door windows - $40 ea
Front side door windows - $40 ea
Rear quarter windows (back door, alongside power window) - $20 ea.
Sunroof glass and tracks - $100
Right rear cargo window with antenna - $30
Seat belts $60 each
Rear buckles $20
Airbags - driver and passenger - $50 each - Shipping $25 (UPS or FedEx)
Limited flares, silver - $40 ea
Cargo cover brackets (all 4, oak) - $50
3rd brake light with plug - $40
Interior plastics and panels - INQUIRE (many available)
Cargo panels - $80 for the pair
Dashboard - $50 Local pickup only
Tow hitch receiver with brackets - Local pickup only
Dome light - $10
Tweeter mirror pods, one damaged - $15
Dash fuse cover - $15
Limited steering column covers - $20
Dash center piece (left side) - $10
Auto 4WD shifter mechanism - $60
Resistor - $10
Airbag sensors - $10 each
tan grab handle - $15
throttle pedal - $10
Running Light relay - $15
ABS module - $30
4WD computer - $30
Airbag computer - $30
Deceleration sensor - $10
Antenna relay - $15
Limited temp sensor - $5
Sun visor clip - $5
Fuel tank access cover (under rear seat) - $10
Wiper arms (pair) without caps - $20, with caps $25
Wiper arm caps - $5 ea
ABS/TRAC relay - $10
Buzzer - $10
EVAP / charcoal canister - $50
Door switches - $5 ea
Door lock tabs - $5 ea
HVAC head unit for sale? and is it digital?
Did it come with a roof rack?
Interested in the Spoiler
HVAC control sold already sorry
Roof rack met the freeway during the rollover, but all the small cross bars are still good. Big cross bars broke.
Spoiler made it out unscathed and is available along with the mounts. Pm me on this with your location and I can get shipping figured out for you
Would you happen to have this piece by any chance? If so how much shipped to 50138?
I do have it. I'll double check the condition and get a photo to you by tomorrow.
Shipping via USPS flat rate will be around $17, I can try to see if I can send it for less (maybe at the expense of shipping speed)
Interested in the Rear window glass and the center section of the Rear bumper.
Also the rear upper and lower control arms if you have them. PM me @ ChildrenofBodom
Did you have the following shipped to 78746?
Is your car white?
Gas door cover in OK condition?
Speedometer/odometer cluster with wiring cable?
Steering wheel
Center console storage box/arm rest? The top part that opens and closes?
The whole frame is still intact as a roller so I'm not quite ready to separate the arms.
Center section of rear bumper is available and in good condition, no dents
Some rear window glass available (which one exactly?)
Is your car white?
Steering wheel
White, yes. Sorry, all body got destroyed with the exception of the passenger fender, some flares, and rear mudguards.
Speedometer cluster sold.
Steering wheel available, has a gouge in the leather from broken windshield. I can get you a photo if still interested. Shame, it is a nice wheel otherwise. Airbag available as well.
Center console was missing from the truck.
Selling the catalytic?
I have it, single cat. PM me with an offer because I have been debating keeping it or not. Local pickup only please
Do you have the RS3000 system and if so, how much for the remote(s)? Shipping to 95350
The truck does in fact have the system, but the FOBs were missing. Sorry.
Did the headlight housings make it through the rollover?
Sorry, the truck didn't have headlights when I bought it.
SOLD and/or SHIPPED
Full carpet Oak - $60 SOLD
Gauge cluster surround piece woodgrain - $50 SOLD
Ignition switch surround piece woodgrain - $20 SOLD
Limited wood grain shifter surround (4wd) with push button transfer case knob - $50 SOLD
Front seats, leather, power, need reupholstery SOLD
Rear seats, leather, fair shape, with headrests SOLD
Jhunt
