3rd Gen Rear Diff compatibility information?
triangles
Member
I have a dying 3.58 rear differential. I've been finding all sorts of conflicting information. Since I have to replace it, I thought why not put an E-locker in it. I have seen the difference and thought about doing a swap for the factory E-locker but I don't want a 4.3 ratio and an aftermarket locker looks like less work than modifying the axle housing. I want to stay with a 3.58 rear end and go with an aftermarket e-locker. Problem is I am finding all sorts of conflicting information. What I have found so far is that the following ratios were put in 3rd gens:
-3.58 V6 2wd
-3.73 4 cyl. 2wd
4.1 V6 4wd
4.3 V6 4wd
My main problem is some sources say the 3.58 and 3.73 are 7.5" ring gears where the 4.1 and 4.3 are 8" ring gears. I'm assuming this is the OD of the ring gear but I'm not sure I could also see this being the bolt circle of the ring gear. I found an E-locker for the 8" diff so I need to figure out if the 3.58 is an 8" or if it is 7.5 inch ring gear which I assume doesn't fit the e-locker. Can anyone shed some light on what I need to measure to figure out if my 3.58 diff is 7.5" or 8"? FYI it's a '96 2wd with axle code A01A.
Also looking for information on what years and models are compatible. I just plan to swap the dif carrier. I have no desire to swap the whole axle. I'm curious if there are other gear ratios on other Toyotas that would give me more options, plus looking for more junkyard sources. As best as I've been able to find it sounds like '96 to 04 tacoma and 4runner should fit. Not sure about the '03 and '04 4runner with those being 4th gen. If anyone has information relevant to this, please let me know.
Before anyone chimes in about why I want a locker in a 2wd, it's a pavement princess but it gets snowy here and having 2wd instead of 1wd on snow and ice is what I'm going after. I have a 4x4 for my offroad fun. Also looking to stay with the 3.58 rear for freeway fuel economy reasons. There's no reason to be turning 3k+ RPM at 80 mph. 2500 rpm @ 80 is nice.
I'd suggest calling east coast gear supply. They are good at what they do. Ask the exact question you asked here.
IIRC the 3.58 uses a smaller diff to fit that ratio vs the 4.1/4.3.
-3.58 V6 2wd
-3.73 4 cyl. 2wd
4.1 V6 4wd
4.3 V6 4wd
Sounds like you have a 'small tire' V6 auto? That's how my 4Runner started.
It is a 3.73 8" diff, compatible with all other 8" (non-e-locker) diffs. You can confirm this with a '"spin test" of your axle. Yes, I know your axle code is A01A, my door sticker says the same. It is still an 8" with 3.73 gears.
A couple of paths forward:
- 30.6" tires on 16" or larger wheels, 4.10 gears and upgraded brakes (the 16" wheel trucks got larger brakes than the 15" wheel trucks). Highway RPMs will be the same.
- e-locker or other locker/LSD carrier rebuilt with your stock gears, assuming the gears are still in good shape.
- Used V6 2WD rear diff as a core, rebuilt the same as option 2. Should be CHEAP since no 4WD guy will want it and they last a long time with minimal maintenance.
I went from 3.73's with small tires to 4.10's with "metric 32's" and 4WD swapped to 4.88's with those same size tires. I never really went above 70mph anyway in the 4Runner, so now I cruise at 2500rpm at just under 70mph.
-Charlie
I appreciate the input but I am fairly certain it is 3.58 as my 4cyl 4Runner has 3.73 and runs about 150ish rpm higher at 80mph. I guess I'll find out when I tear into it and can count teeth.
The 15" wheel auto 2WD 4 cylinders run a 3.90 rear gear... which gives you that extra ~150rpm at 80mph cruising speed.
Plug the following into a gear calculator:
80mph or 2500rpm
0.705 ratio 4th gear (OD)
3.73 gears
28.3" tires
-Charlie
Well Charlie you are 100% correct. I finally got around to pulling it out. My rear diff is a 41/11 or 3.727 gear ratio. Also pleasantly surprised it had 4 spider gears instead of the 2 I thought it had. Now to rebuild it with a truetrac
charlesz
