3rd gen retro headlights
SIKHILUXSURF
testing the waters i just finished this retrofit brand new headlights with fx45 bi xenon projectors and custom shrouds the are the most nicest retros you will see any where, the cleanest lighting you can ever buy. asking $500 considering all the time effort and customization it takes to build these headlights. you will never see a set exactly like these any where. testing the waters to see how many where interested in these as i got many emails during my build up on these. they will come with bulbs all you will need to get them to work are the balast and the wiring harness from retrofit source which are cheap as if need i can aquire these for you at an added charge. i will get better pictures of the retrofit on the rig in the morning.
No no...I understand.
But are they made by Stanley?
I know TSX, S2000, LS430 projectors are made by Stanley.
bump these must be gone long ago?
the light output looks outstanding
I like your black on black look
truck looks very nice.
a
So how much would plug and play set cost? What is the life span of the bulbs? Also, how does this work with DRL's?
Re: a
this is not a pnp hid kit this is a actual hid projector conversion into a 3rd gen housing. the ife span on the bulbs depends on which bulbs you use. this setup cost 800 to reproduce including all parts with new headlights and labor. check around the retrofit lighting forums the usuly charge about 625-675 just for projectors and labor and you have to supply your own headlights and other parts.
