3rd gen suspension suggestions?
Tanyav14
im thinking of getting my third gen the toytec boss suspension or the ultimate lift, does anyone have this set up? how does it ride? pros cons?
feel free to give me suggestions on other set ups
:suspicious:
:suspicious:
What kind of driving do you plan on doing? Is it a DD and a off-road truck?
Both! :). so im looking for something that's comfortable to drive on the daily, but also to take it wheeling on the weekends
There's a whole lot of subjectivity to what is "comfortable" to one and unbearable to others. Some have returned billsteins because they thought they were way too stiff for daily driving, and others love them.
If you are planning on lifting, I'm not sure if there's any soft shocks or struts out there. Others might chime in and be able to compare the different brands and one might be a bit softer, but for the most part your suspension will be stiff, which is what is preferred for wheeling.
If you are adding a mild or no lift, KYB's are a bit of a middle road which is what I currently have. The stock Tokico's are actually pretty good and fairly cheap to replace, you just can't lift with them since they are too short. They are the best for daily driving as far as shock absorption goes and give that "luxury" feel.
Ironically, I found the adjustable Billies to be way soft and super comfortable.
At the end of the day, if you want a off-road truck you will want the money in on a solid set of coilovers, i.e: Icon, Camburg, Fox (2.5 not 2.0), maybe even Radflo (if you have piles of cash), and so on. If you want a decent entry level I'd send you towards the OME set-up. I personally think the entry level set-ups are all comparable and you should just read through the earlier posted thread for a run down on many of the options.
Wheelsoffroad.com and sonaransteel.com can help broaden your options.
Yes! haha that's hilarious! yeah ill go add you guys on fb, hopefully we can go wheeling sometime, ill invite my brother too lol hes got an 85 4runner.:guitar3:
I have the toytec boss w/ 600lb coils up front & OME 890s in the rear on a stock set up and it rides really well as my DD. It feels slightly stiffer (in a good way) compared to the factory suspension. Toytec also offers the 550lb front coils if you wanted something a little softer. When I called them, they told me that the 550 coils would feel closer to how the factory suspension feels and the 600 would be a little stiffer but would handle turns slightly better & have less body roll & I'd have to say they were pretty accurate in how they described it. I have driven a 3rd gen with the toytec ultimate set up & I couldn't tell the difference. The ultimate I drove had the same front and rear coils that I have but don't remember which shocks they had in the rear. I went with the boss mainly bc toytec said it would have a slightly better street ride then the ultimate. But like I said, I couldn't tell a difference between the two. The ultimate is a little cheaper so you may want to take that into consideration.
Toytec Ultimate Lift
I have the Toytec Ultimate Lift with the Eibach 600# silvers and the 5100's in the front with adjustable UCA's and 1" diff drop. Running the OME springs and OME sport Shocks in the rear and love the ride and the way it sits.
It's a recreational off road vehicle and spends time on the highway as well. The ride is not too stiff with the 600# springs. I'm adding a schrockworks bumper and winch and the guys at Toytec said the 600# springs will do just fine. 650's are really stiff.
Decided to go with the Toyo ATII's 4ply's in a 285/70R/17 inch wheel instead of a 285/75/16. Both are at 32.8" but the larger wheel size adds more stability (less rubber) than the the 16" wheel. You'll notice the difference mostly on the highway during those windy days. I think i have an A+ set up for the driving that I do. Like all before me have said, depends on what you plan on doing. There are a ton of options out there and different flavors for everyone.
Just to answer your original posting - Yes I have the Toytec Ultimate and am extremely pleased with the ride - on and off road.
I am new to the T4R world. Got the wife a 99 SR5 2WD and we are loving it. Had the opportunity to ride in the back seat and was Not pleased with the ride. I believe suspension is original. Looking to replace components.. I know I should do most everything.
Its a DD so not looking to get crazy with it but Briefly looked into the Bilstien 5100s 0-2" lift(will be keeping it at 0 lift) It seems like this is a decent upgrade from stock without getting too custom.
Is this accurate?
Should/Do I need to replace the coils as well??
Probably will get new bushings and stuff.. What else should a T4R Noob but decent home mechanic know?
All suggestions are welcomed and appreciated!!
Is this accurate?
If your rear suspension is bottoming out with hard hits then it's time to replace your sagging springs with new or add some spring spacers back there. Two must checks/replace are lower ball joints and radiator. If you don't know when the lower ball joints were replaced last or they look damaged/old then replace them now before they fail and cause a lot of damage. OEM is the general recommendation for replacement lower ball joints, and make sure to get the lower ball joint bolts as well. If the radiator is brown/cracking/generally old looking then it would be a good idea to replace it before the transmission cooler in the radiator fails causing coolant and transmission fluid to mix causing transmission failure in 99% of vehicles that this happens to.
Do you have the model # for the KYB's? Thanks
What coils are you using? Thanks
freddygino
