3rd Gen vs. 5th Gen
The 3rd Gen has a rear locker as well.
How does KDSS give it more articulation?
But the 3rd gen has a totally open front differential. The 5th gen Trail has super A-TRAC controlling the front axle along with the rear locker...it is like having a rear locker plus a very effective front limited-slip differential. So, unlike the 3rd gen, a 5th gen (and to a lesser extent the 4th gen) can still move forward even if only one front tire has traction.
KDSS improves articulation by relaxing the anti-roll bars front and rear when off-roading, thus dramatically improving articulation. On-road, the anti-roll bars are thicker than normal to provide excellent cornering. So, it is the best of both worlds all in one.
Yeah... you dont seem to understand that Safety alone does not make a "superior" vehicle
However, even the IIHS rep in the video I posted states that heavier vehicles in the same class tend to do better in crash tests.
You have still yet to prove to me that "more technology" makes a better more reliable, higher quality car...
or do I need to bring up plastic accelerator pedals of which NO Toyota had a problem with in the 90's and early 2000's... :bigok:
IIHS states that the heavier car wins. Ok, fine. The 5th gen is 700-800 lbs HEAVIER than the 3rd gen. There. The 4th gen is 500 lbs heavier than 3rd gen. Not only is the 5th gen heavier, it is also better designed with a stronger frame. I don't understand why you keep on bringing up the heavier vehicle argument??
Superior? Ok, lets see...the 5th gen is a whole lot better on-road...not even in the same ballpark! It is better off-road. It is stronger, both structurally and crashworthiness. It is roomier. It has better off-road equipment, including disc brakes, better CRAWL ratio (one of the most important factor in off-roading!), super traction control, etc.. And to date, the 4th gen is just as reliable and durable as the 3rd gen, which means that the 5th gen will likely be just as reliable and durable. So, is the 5th gen superior? I think so. Why would think any other way???
Does smallish drum brakes make a superior car for you? Does an "AVERAGE" crash score make a superior car for you? You tell me. Yeah, like i said above, the only thing that is really superior in the 3rd gen is the interior plastics. Anything else i am missing?? Tell me your side of the argument.
Is the 4th or the 5th gen 4runner on the gas pedal recall list?? Did i miss something?? Was there any 5th gen 4runner needing a head gasket recall like the 1996 4runner needed??? Or how about the butt sagging recall due to substandard coils or bumpstop??
I am just amazed at this argument...wow.
1999 3rd gen 4Runner SR5 V6 Auto : Stock specs from JA's site
Approach Angle: 36 Degrees
Departure Angle: 29 Degrees
Ground Clearance: 11.0 inches
Curb Weight: 3,930 Lbs.
Overall Width: 68.1 inches
Overall Length: 183.3 inches
2010 5th gen 4Runner SR5 V6 Auto: Stock specs from Toyota
Ground clearance (in.): 9.6
Approach/departure angle (degrees): 25/24 (33/26 Trail)
Curb weight (lb.): 4675 (4750 Trail)
Overall width: 75.8
Overall length: 189.9
Thai, as you can see, there is a LOT more than just the width that is different between the 3rd and 5th gen. i suggest you are the one that does your research before spouting off.
other comparisons:
Reliability: 3rd gen is proven. 5th gen is too new to tell.
Safety: newer generation of vehicles almost always improve in safety so i'm willing to bet the 5th is safer however the 3rd was the safest SUV of its time
Styling: i personally hate the direction that Toyota is going with all their vehicles and the 5th gen is no exception. thats just my opinion so feel free to disagree. 3rd gen was one of the best IMHO. just ahead of the 1st.
Pricing: pretty much the same for what i can tell:
Power: i don't think i even have to talk about the one (5th gen wins btw)
On road: same with safety.
In short, the 5th gen improves in some areas but in worse in others. i don't think many people will disagree with me when i say that the 4runner is slowly becoming less off road oriented and more soccer mom/minivan-like. just look at pictures of the generations. most people with agree that the 1st is the best offroader. i personally feel that the 3rd gen was the best compromise between the two. and finally the most important thing about the 3rd gen, it came in a manual.
yes i know i haven't hit all the differences but i just worked a 12 hour day so :sleepy:
Overall width: 75.8
other comparisons:
In short, the 5th gen improves in some areas but in worse in others. i don't think many people will disagree with me when i say that the 4runner is slowly becoming less off road oriented and more soccer mom/minivan-like. just look at pictures of the generations. i personally feel that the 3rd gen was the best compromise between the two. and finally the most important thing about the 3rd gen, it came in a manual.
:iagree: especially on the manual tranny part, cause any old assh0le can hit the gas and go up a hill.
Overall width: 75.8
other comparisons:
And yet, you are the one that is wrong about ground clearance. Go...look under your 3rd gen 4runner. Measure from the ground up to the lowest part of your underbody. Tell me...is it 11"?? Hell no! Your lowest part is the rear axle pumpkin which is around 9.6-9.8" off the ground. Toyota fakes data BTW. 11" is one of the biggest marketing BS! Check it out yourself...in fact, all of you 3rd gen owners, go check it. You will be laughing all night long! :D You guys actually think that the ground clearance is 11"??!! I guess marketing does work afterall!!
As for the approach and departure angles, i have my doubts too. When i had my 3rd gen, i rubbed my underbody, front, rear fenders way more than my brother's 2001 lX470 over the same obstacles, which supposedly had inferior "numbers."
And yeah, the weight difference is huge!
Anything else?
As for the approach and departure angles, i have my doubts too. When i had my 3rd gen, i rubbed my underbody, front, rear fenders way more than my brother's 2001 lX470, which supposedly had inferior "numbers."
Anything else?
did i not say those were both Toyota specs?
i don't disagree that the rear diff is lower than 11 inches but tell me how you know that toyota didn't fake those specs on the 5th gen too and it is actually 7 inches to the rear diff.
glad to see you ignored everything good i mentioned about the 5th
Anything else?
Well if they falsly marketed the clearance of the 3rd gen why the hell would i beileve there statements about the 5th.
Well if you scraped the rocks/obstacles, then exactly that happend YOU did it, the car can clear it.
And yeah the weight difference is huge, but then again 6" shorter and 7" skinny takes up a lot of room ehh?
BTW if this so called Traction control was so ****ing superior offroading then tell me, How many of the trucks that participate in King of the Hammers have Traction Control?
or talk trash on the internet, apparently.
My stock Trail Edition kicks the snot out of any stock 3rd Gen 4Runner and I fully expect I will still feel that way when it has as many miles as the 1985 Toyota pick-up parked next to it.
You don't like my ride? Don't buy one. :thanks:
Since you completely miss my point on everything... as is standard in all your little posts... Ill just say this...
Go buy a 5th gen 4runner, and We will see how well it holds together in 14 years... Your 5th gen has had what 6? 7 months on the road? Im so glad you are so knowledgeable about cars that you can say that the 2010 4runner is better already than the 3rd Gen, one of the most reliable cars on the road EVEN TODAY... how many 2004 Fords have I seen dead on the side of the road or even Caddies/chevys/dodges/etc. and I have seen exactly 1 4runner dead on the side of a road...
Do you even own a 5th gen? why dont you go get one and we can put our 4runners to the test, no, we will put your 5th gen to the test of Thegreenmonsters stock 97 who just this weekend showed up a 4th gen lifted runner!!
also, just by looking at johns picture. you can see the differences in the angles. johns seems to sit lower but you can clearly see that his rocker is way higher and the departure angle is better. yes the 5th is a limited but remember that johns has 13 year old springs, is not a highlander, and has stock tires.
LOL on the talk trash part! LOl
really? Ill put Thegreenmonsters stock 97 up against your Trail Edition!
:frisky:
I really hope that the 2010 will be there with your 85 or my 96 toyota, but from what I have seen from the 2010, I just dont think so.
and maybe I havent really given the new kid a shot, but it feels so fake and cheap and plasticky... I really should drive one more, but The 3rd Gens are just SOOO good, I see them all over the road here in colorado and they all look and run great still! I just dont see the 2010s following in those footsteps.
And those are some BIG footsteps, but you know what, I guess you are right, only time will tell :driving: Happy driving! Im out!
please tell me exactly how your Trail kicks the snot out of the 3rd gen. i'm serious. if you want to make an argument, give some facts to back it up. while i disagree with Thai on this subject, he definitely gives me a good argument :cheers: i am also interested in why you feel that the 5th will be so reliable. as i said before, the 3rd gen is proven and the 5th is too new to tell. i'm sure no one "felt" that their head gaskets were going to go on the 3VZ
Are you kidding me?
Beats it in what way?
the reason the 5th gen is better TO ME, over the 3rd gen......is that the interior is more updated... more buttons to press...more confusing dashboard look. more lights and switches..ya know?
Well, because a 5th gen member measured it at 9.6 and even had a picture of it! :)
happen to have a link?
i'm not saying i don't believe you...i just actually want to see it :D
however as you may know, the clearance to the rear diff is not as important as others when it comes to off road. as i said before, the rocker has way more clearance on the 3rd gen than on the 5th. i can't ever remember being hung up on my rear diff while i was offroad. however, i have gotten hung up on my rocker, gas tank, front skid plate, rear skid plate, rear bumper...front bumper more time then i can count.
:frisky:
Are you kidding me?
In the same way, and by the same standards, put forth by the OP JohnsD90: subjective standards and opinions pulled directly out of my ass :D
I'm not knocking the 3rd Gen so much as the ignorance inherent in an argument based on looks and opinion. Steel might be more durable, but I'm never going to worry about my plastic bumpers rusting away. As for quality, only time will tell, but I've been in every generation of 4Runner made, and I LOVE my TE specifically because it's not trimmed out to be a pavement princess but meant for off-roading... and it comes with "training wheels" so those who are intimidated by going off-road will feel a little emboldened by it's extra features.
Anything that makes a 4Runner more capable and popular is a BONUS, and the Trail edition does just that... in this assh0le's opinion :peace:
Here is the picture of the 5th gen Trail:
:frisky:
Ok, lets take the driver out of the equation. What makes Thegreenmonsters stock 97 so special? Does he have a rear locker? Lets talk facts and specs of a vehicle, not assumptions nor opinions.
i can respect your opinion. but you original statement sounded exactly like the ignorance inherent in an argument based on looks and opinion
Crookedcat
