3RDgen front drive shaft
neokhz
So I have a 97 4x4 that didn't have the front drive shaft when purchased. I got a DS yesterday and plan on installing it tonight. It didn't come with any of the bolts for it. Can anyone tell me what size bolts I need to pick up for the install. I planned on picking them up on my way home so that I didn't have to go out again once I leave.
Thank you
You are all wrong.
front d/s is nuts on studs at t/c, nuts and bolts at diff. They are all 11mm x 1.25, Toyota special, very difficult to find elsewhere, except mcMaster-Carr or dealer.
So you need eight nuts, eight washers and four bolts. T/c forward output flange should have four 11mm x 1.25 studs.
37140C
WASHER (F0R FRONT PROPELLER SHAFT)
90204-10002 8
37140B
NUT (F0R FRONT PROPELLER SHAFT)
90179-10059 8
37140A
BOLT (F0R FRONT PROPELLER SHAFT)
90105-10085 4
You are all wrong.
37140C
90204-10002 8
37140B
90179-10059 8
37140A
90105-10085 4
Thanks for the info... I called my local Dealer and they have to order them for me. $56 for them
[MENTION=10169]TheDurk[/MENTION] the part numbers have changed.
90080-10294 FLANGE BOLT x4
90560-10H00 SPACER X8
90080-17239 FLANGE NUT X8
[MENTION=126382]neokhz[/MENTION]
make sure they use the numbers above that I supplied
should be right at $56-$57
You are all wrong.
I learned something new today! :humble:
I was going to pound out the studs and put the bolts in because I thought that someone had wedged the wrong bolts into the flanges lolol. I guess I have some extra driveshaft hardware now...
So for now until I get the real ones I used some Grade 8 bolts, nuts and washers just to test and make sure everything is working and I don't need a T-Case or front diff... Thanks for all the info guys.
If you go with hardware that's not OEM be careful. You're saying Grade 8 hardware which is the imperial system. You're going to need to go metric on this, and you'll want a Class 10.9.
Imperial Grade 8 is going to be a Metric Class 10.9, and Imperial Grade 5 is going to be a Metric Class 8.8. Grade 8 bolts have a yield strength of 130,000 psi. Class 8.8 bolts have a yield strength of 92,000 psi
Nothing wrong with using Class 10.9 fasteners either. As I repair things I've been swapping bolts out to 12.9's due to the fact that they're easier to find.
I also use BelMetric for all my metric needs.
bobdjr41
