captwalker87
i discovered the other day that thrust bearings are an important item in my wonderful little 3.slow. i also discovered that advancing your timing is a bad thing to do with bad thrust bearings. but this is all after i discovered that my cam pulley flew off, and the cam itself is an inch further outside the engine that it should be, my belts are torn to shreds and i no longer have power steering, ac, or a functional charging system. im just the ultimate detective. anyways, it was about time for that thing to die anyways. 237000 miles, and about 200000 of them are highway miles in the desert. Ill cut to the chase: im yanking that motor for one i found at my local junkyard (very surprisingly) for $600. complete motor. i thought it was a good deal. Anyways, is there anywhere that has a write up on removing and replacing the 3VZE? pictures would be nice too. thanks in advance.
