Greetings -
I have a 1992 4Runner with a partially/maybe crapped-out 3VZE. I bought the truck cheap knowing the engine had a loud knock. It came from a guy who had owned it for a month and decided he did not have time to fool with it. Besides the knock (!) the truck is in very good shape, body straight, paint good, interior excellent, new clutch, new tires, CD changer, 5 spd (with 4.30 gears), no undercarriage dents, no wrecks, AZ vehicle, 152k. I have receipts
for about $2500 of stuff (tires, clutch, ball joints, idler arm, brakes, main seal, more). And besides the knock it runs really well, no smoke, no sooty or oily exhaust, clean spark plugs (a small bit of oil fouling on #6), very smooth idle, no other strange or unusual noises. The truck was driven knocking but as near as I can figure it was less than 10 miles.
Hoping that it was timing belt related I unfortunately found that the #2 rod bearings were pretty well beaten flat and partially broken (bits in the oil pan) and had rotated around the journal. Before taking the cap off I could move the rod in and out a bit--clearly the source of the knock. I pulled the other caps and the bearings all look good (as far as I know, I can take pics). I don't know the history of the engine as it was apparently replaced not long ago (wrecking yard numbers, oil pan was off). I suspect the knock occured soon after major work was done and the owner, in the Army, was transferred and simply gave up on the truck.
I have never really delved into bottom ends so I have to figure out what to do with this. The obvious answer is to swap for a 3.4 but that must wait a bit. I would like to fix this so I can drive it (at least long enough to go pick up a 3.4!).
I guess my question for the experts here is how much effort is this 3VZE worth. A mechanic friend suggested just replacing the #2 rod bearings and driving it until it dies. My current thought is to replace all rod bearings (#2 may have to be oversize), relatively cheap, and be done with it. As I understand it the bearings can be replaced from underneath without pulling the heads (I want to avoid this). The head gaskets were replaced at some point, and the timing belt (but it could use another, especially since I have the front torn apart). As to why the #2 failed and the other bearings look good...? The crank journal oil hole drips oil so I don't think it is plugged (restricted?...but it drips as much as the others). Perhaps bearings were installed incorrectly? #2 a problem area? I have not checked rod end-play.
Any and all help is much appreciated! Thanks; cheers, Joel
