4.0 crankshaft pulley bolt head size
Getting sorted to install supercharger and the one thing Im lacking is the correct size counterweighted socket. can anyone verify its a 16mm? Thanks you
Not to be a jerk but did you check the Magnuson install manual? I believe stock is 22mm and the one in the kit is 24mm. I’m going off of memory so I could be off.
If you read through the manual(you can get a pdf online from their site) it will pretty much tell you everything you need for the install. They pretty much detail every single step/bolt you need to touch. I read through it before I bought the kit to make sure the install was a DIY job.
utkrstam
